bannerimg
Deliver to
USD $95
DJI Mini 3 Pro
Provides a max flight time of 45 minutes (Mini 4 Pro)/47 minutes (Mini 3 Pro)/51 minutes (Mini 3)*. Explore more of your surroundings and fly with peace of mind.
Tips
* Measured in a controlled test environment. Specific test conditions are as follows: flying forward at a constant speed of 21.6 kph in a windless laboratory environment at 20 meters above sea level, in photo mode (without photo taking operation during flight), with Obstacle Avoidance Action set to Off, and from 100% battery level until 0%. Results may vary depending on the environment, actual use, and firmware version. With the Intelligent Flight Battery Plus, the aircraft will weigh more than 249 g. Always check and strictly abide by local laws and regulations before flying.
Intelligent Flight Battery Plus × 1
Model: BWX162-3850-7.38
Weight: Approx. 121 g
Capacity: 3850 mAh
Nominal Voltage: 7.38 V
Max Charging Voltage: 8.5 V
Battery Type: Li-ion
Energy: 28.4 Wh
Charging Time: 101 minutes (with the DJI 30W USB-C Charger and the battery mounted to the aircraft)
78 minutes (with the DJI 30W USB-C Charger and the battery inserted into the Two-Way Charging Hub)
Charging Temperature: 5° to 40° C (41° to 104° F)
Recommended Chargers: DJI 30W USB-C Charger or other USB Power Delivery chargers
DJI Mini 4 Pro
DJI Mini 3 Pro
DJI Mini 3
We Value Your Privacy
Cookie Preferences
