1/7
PhotosShowreelIntro
DJI Mavic 3
USD $2,049USD $2,199
  • 4/3 CMOS Hasselblad Camera
  • 46 Minutes of Flight Time
  • Omnidirectional Obstacle Sensing
  • 15km Max Transmission Range
  • Advanced Return to Home
Select Option
Compare Options
What’s Inside the Box?
  • DJI Mavic 3
  • DJI RC-N1 Remote Controller
  • Spare DJI RC-N1 Control Sticks (Pair)
  • DJI RC-N1 RC Cable (USB Type-C Connector)
  • DJI RC-N1 RC Cable (Lightning Connector)
  • DJI RC-N1 RC Cable (Standard Micro-USB Connector)
  • DJI Mavic 3 Intelligent Flight Battery
  • DJI Mavic 3 Low-Noise Propellers (pair)
    × 3
  • DJI 65W Portable Charger
  • DJI Mavic 3 Storage Cover
  • Type-C Cable
Moments by You
  • Timelab Pro
  • Karl Shakur
  • Karl Shakur
  • 阿岛儿
  • Jorge de la Torriente
  • Jason Charles Hill
  • Karl Shakur
  • DJI Mavic 3
    Flagship drone for advanced shooting
    895 g
    4/3 CMOS
    20 MP, DNG (RAW)
    5.1K/50fps, 4K/120fps
    46-minute Flight Time (no wind)
    O3+, 15km, 1080p/60fps Transmission*
    Complete Omnidirectional
    ActiveTrack 5.0 [6]
    Advanced RTH
    Standard RC
    8 GB internal storage
    28x Zoom
    MasterShots
    APAS 5.0
  • DJI Mavic 3 Cine
    Flagship camera drone for pros
    899 g
    4/3 CMOS
    20 MP, DNG (RAW)
    ActiveTrack 5.0 [6]
    Advanced RTH
    DJI RC Pro (high-bright display)
    1TB SSD high-speed internal storage
    28x Zoom
    MasterShots
    APAS 5.0
    Apple ProRes 422 HQ encoding
    Apple ProRes 422 encoding
    Apple ProRes 422 LT encoding
  • Compared to DJI Mavic 2, what major upgrades does Mavic 3 have?
    DJI Mavic 3 is DJI's next-generation flagship consumer camera drone. Compared to Mavic 2, major upgrades include:
    1. Mavic 3 offers significantly improved imaging performance thanks to its 4/3 CMOS Hasselblad camera and 24mm-equivalent lightweight lens. It can record up to 5.1K/50fps or 4K/120fps videos.
    2. Mavic 3 Cine supports Apple ProRes 422 HQ, Apple ProRes 422, and Apple ProRes 422 LT encoding, offering better image quality and greater flexibility during post-processing.
    3. The flight experience has also been comprehensively improved with the flight time extended to 46 minutes. And thanks to incredibly stable O3+ technology, video transmission can reach up to 15 km.
    4. DJI Mavic 3 is equipped with an omnidirectional obstacle sensing system and supports the upgraded APAS 5.0 and Advanced RTH, letting creators enjoy safe flight with peace of mind.
  • What's the difference between the combos?
    Compared with the standard Mavic 3 combo, DJI Mavic 3 Fly More Combo includes two additional Intelligent Flight Batteries, one Battery Charging Hub, one Convertible Carrying Bag, and one ND Filters Set (ND4/8/16/32) to help you explore and shoot in more scenarios.
    Compared with the DJI Mavic 3 Fly More Combo, the DJI Mavic 3 Cine Premium Combo includes a Mavic 3 Cine aircraft that supports Apple ProRes 422 HQ, Apple ProRes 422, and Apple ProRes 422 LT video encoding and has a built-in 1TB SSD, an upgraded DJI RC Pro with a high-bright display, one ND Filters Set (ND64/128/256/512), a 10Gbps Lightspeed cable, and other accessories that help facilitate professional-level imaging.
  • Is Mavic 3 compatible with the accessories of the Mavic 2 series?
    No.
  • What are the advantages of Mavic 3's imaging system?
    Mavic 3 is equipped with a dual-camera system. First, the Hasselblad camera has a professional-level 4/3 CMOS sensor and supports the Hasselblad Natural Colour Solution, allowing users to get stunning results without the need for post-processing. Mavic 3 Cine goes one step further, offering support for Apple ProRes 422 HQ, Apple ProRes 422, and Apple ProRes 422 LT encoding. Second, the tele lens of the dual-camera system supports Explore mode for 28x hybrid zoom, allowing you to see more of your environment and plan shots with ease.
  • How does the omnidirectional obstacle sensing work?
    Multiple wide-angle vision sensors onboard work together seamlessly with a high-performance vision computing engine to sense obstacles in all directions precisely and plan a safe flight route that avoids obstacles.
  • Compared with O3, what improvements does O3+ have?
    The O3+ transmission system has a transmission range of up to 15 km and supports 1080p/60fps real-time transmission.
    Note: Unobstructed, free of interference, and when FCC-compliant. Maximum flight range specification is a proxy for radio link strength and resilience. Always follow local rules and regulations and fly your drone within your visual line of sight unless otherwise permitted.
[1] Measured with Mavic 3 flying at a constant speed of 32.4 kph in a windless environment at sea level until the battery reached 0%. Data is for reference only. Please pay attention to the RTH reminder on the DJI Fly app during flight.
[2] Unobstructed and free of interference. Actual resolution may vary depending on the quality of the transmission signal.
[3] DO NOT use the aircraft in severe weather conditions including heavy wind exceeding 13.8 m/s, snow, rain, fog, hail, or lightning. DO NOT fly the aircraft 6,000 m (19,685 ft.) or higher above sea level. DO NOT fly the aircraft in environments where the temperature is below -10° C (14° F) or above 40° C (104° F). DO NOT take off from moving objects such as cars or boats. DO NOT fly close to reflective surfaces such as water or snow. Otherwise, the vision system may be limited. When the GNSS signal is weak, fly the aircraft in environments with good lighting and visibility. Low ambient light may cause the vision system to function abnormally. DO NOT fly near areas with magnetic or radio interference. Common sources of magnetic or radio interference include Wi-Fi hotspots, routers, Bluetooth devices, high-voltage lines, large-scale power transmission stations, radar stations, mobile base stations, and broadcasting towers. Be careful when taking off in desert or beach areas to avoid sand entering the aircraft. Fly the aircraft in open areas. Buildings, mountains, and trees may block the GNSS signal and affect the on-board compass.
[4] DJI Mavic 3 Cine supports Apple ProRes 422 HQ, Apple ProRes 422, Apple ProRes 422 LT and H.264/H.265 encoding, while Mavic 3 only supports H.264/H.265 encoding.
[5] Actual available storage space may be reduced due to system configuration. For more details, see the Mavic 3 specs.
[6] ActiveTrack is not available at video resolutions higher than 4K or frame rates over 60fps.
