Generally speaking, FPV drones differ from traditional drones in two major ways. The first is the immersive flight experience provided by the goggles. The second big difference is the flight itself. Compared to most camera drones, FPV drones typically allow for much higher speeds and limitless maneuvering capabilities with no angle limits on any of the axes. Because of this, FPV drones have typically required a much higher level of skill to fly.
- Immersive Flight Experience [1]
- 4K/60fps Super-Wide 150° FOV [2]
- 10km HD Low-Latency Video Transmission [3]
- Brand-New S Mode
- Emergency Brake and Hover [4]
Don't Miss Top Accessories
What’s Inside the Box?
DJI FPV Drone
DJI FPV Intelligent Flight Battery
DJI FPV Propellers (Pair)
× 4
DJI FPV Gimbal Protector
DJI FPV Top Shell
DJI FPV Remote Controller 2
Spare Control Sticks (Pair)
DJI FPV Goggles V2
DJI FPV Goggles Antenna (Dual Band)
× 4
DJI FPV Goggles Battery
DJI FPV Goggles Power Cable (USB-C)
DJI FPV Goggles Headband
DJI FPV Goggles Foam Padding
DJI FPV AC Power Adapter
DJI FPV AC Power Cable
USB-C Data Cable
USB-C OTG Cable
What’s the difference between DJI FPV and traditional drones?
What is the difference between DJI FPV and traditional racing drones?
DJI FPV has a built-in imaging system, high-definition, low-latency transmission with a range of up to 10 km, and a battery life of approximately 20 minutes. The integrated, ready-to-fly design means users don’t need to assemble the drone themselves. DJI FPV isalso equipped with advanced safety features such as emergency brake hovering, intelligent return to home, and DJI Care Refresh service for added flight protection and greater peace of mind during flight.
Is the DJI FPV Combo worth it?
The DJI FPV Combo comes with everything you need to start flying. It includes the FPV Drone, Goggles V2, Remote Controller 2, DJI FPV Intelligent Flight Battery, DJI FPV Goggles Battery, DJI FPV AC Power Adapter, DJI FPV Propellers, and other related cables and accessories. For anyone interested in diving into the world of FPV flight, it’s the perfect way to do so.
What is the Motion Controller? Is it worth it?
The DJI Motion Controller is a small, hand-held device that revolutionizes the aerial experience. This compact device allows the aircraft to maneuver based on your natural hand motions, delivering an ultra-intuitive experience and allowing even beginners to maneuver like seasoned FPV pilots.
I am a beginner/new pilot. Where can I find tipsabout using DJI FPV?
DJI FPV comes with a user manual and comprehensive tutorials, which you can get from the Flight Academy in the DJIFly app. DJI also developed the DJI Virtual Flight app [5], which lets users practice flying virtually before taking off in the real world. All you have to do is connect the DJI FPV Goggles V2 and remote controller to your mobile device with the Virtual Flight app and you’re ready to master FPV flight in a risk-free way.
Does DJI FPV support obstacle detection and avoidance?
The DJI FPV aircraft comes with forward and downward vision sensors that can automatically detect objects and decelerate whenflying in N mode. However, there is no automatic avoidance function. When obstacles are detected, the aircraft will slow down but will not stop completely unless controlled to do so by the pilot.
Do I need to assemble the DJI FPV drone myself?
No. Like many previous DJI drones, DJI FPV doesn’t require any assembly. Simply open the box, install the propellers and battery, and DJI FPV is ready to fly. However, DJI FPV does have a modular design with easily replaceable parts. Users can replace the top cover, gimbal camera, and landing gear if any of these parts become damaged.
What is the maximum transmission range of DJI FPV?
DJI FPV comes with DJI O3 (OcuSync 3.0), DJI’s best transmission system yet. DJI O3 was adapted to match the unique needs of DJI FPV, and features crystal-clear real-time video transmission at distances of up to 10 km.
1. Before flying DJI FPV, check local laws and regulations. Ensure that your flights are conducted safely and in accordance with all local laws and regulations.
2. The 150° FOV is only applicable when shooting at 50 or 100 fps.
3. FCC-compliant. Measurements were taken in unobstructed environments free of interference. Always follow local rules and regulations and fly your drone within your visual line of sight unless otherwise permitted.
4. Obstacle sensing is only available when the aircraft is in N mode. In this mode, DJI FPV will automatically decelerate when it detects obstacles, but it will not automatically stop.
5. The DJI Virtual Flight app currently supports only iOS devices.
6. The DJI Motion Controller is sold separately.
1 business day after payment confirmation
