1/7
PhotosIntro3D
DJI Air 2S
USD $999
  • 1-Inch CMOS Sensor
  • 5.4K Video
  • MasterShots
  • 12km 1080p Transmission
  • Obstacle Sensing in 4 Directions
Select Combo
Compare combos
Don't Miss Top Accessories
What’s Inside the Box?
  • Aircraft
  • DJI RC-N1 Remote Controller
  • Intelligent Flight Battery
  • Battery Charger
  • AC Power Cable
  • Low-Noise Propellers (Pair)
    × 3
  • Gimbal Protector
  • Type-C Cable
  • RC Cable (USB Type-C Connector)
  • RC Cable (Lightning Connector)
  • RC Cable (Standard Micro-USB Connector)
  • Spare DJI RC-N1 Control Sticks (Pair)
Moments by You
  • Instagram @Shortstache
  • Weibo @Thomas看看世界
  • Instagram @Emmett Sparling
  • Instagram @Aaron Brimhall
  • DJI Air 2S
    595 g
    1" CMOS Sensor
    20MP Photo
    5.4K/30fps Video
    31-Min Max Flight Time (no wind)
    12km 1080p Transmission *
    Forward + Backward + Upward + Downward Sensors **
  • Mavic Air 2
    570 g
    1/2" CMOS Sensor
    48MP Photo
    4K/60fps HDR Video
    34-Min Max Flight Time (no wind)
    10km 1080p Transmission *
    Forward + Backward + Downward Sensors **
  • Mavic 2 Pro
    907 g
    1" CMOS Sensor
    20MP Photo
    4K/30fps 10bit HDR Video
    Omnidirectional Obstacle Sensing ***
  • DJI Mini 2
    <249 g
    1/2.3" CMOS Sensor
    12MP Photo
    4K/30fps Video
    10km 720p Transmission *
    Downward Sensor + GPS Precise Hover **
  • What are the main differences between DJI Air 2S and Mavic Air 2?
    The camera performance, intelligent features, obstacle sensing system, and transmission system have all improved significantly. Upgrades include a 1-inch CMOS sensor, four-antenna low-latency transmission, APAS 4.0, added upward-facing dual-vision sensors, and MasterShots.
  • Is the DJI Air 2S Fly More Combo worth it?
    For a small additional cost, the DJI Air 2S Fly More Combo includes some must-have DJI Air 2S accessories that will make flying easier and more enjoyable. This combo includes two extra Intelligent Flight Batteries, a Battery Charging Hub, and a Battery to Power Bank Adapter, providing longer flight time and higher charging efficiency. It also comes with a shoulder bag, an ND Filters Set (ND4/8/16/32), and three spare pairs of Low-Noise Propellers. Purchasing the DJI Air 2S Fly More Combo is significantly cheaper than purchasing the drone and these accessories separately.
  • Is DJI Air 2S compatible with Mavic Air 2's accessories?
    With the exception of the ND filters set and gimbal protector, DJI Air 2S is compatible with most of Mavic Air 2’s key accessories, including the intelligent flight battery, battery charging hub, low-noise propellers, and shoulder bag.
    Click to check out DJI Air 2S’s accessory list.
  • Is DJI Air 2S compatible with the DJI Smart Controller?
    Yes. The DJI Smart Controller is designed to maximize your outdoor flying experience. It comes with a built-in 5.5-inch 1080p screen, providing an ultra-bright display to keep your live feeds easily viewable, even in direct sunlight. The DJI Smart Controller's customized Android system and optimized DJI GO 4 and DJI Fly apps give you freedom from the restraints of conventional mobile devices to ensure faster, focused aerial creation. The Smart Controller also supports third-party apps for a variety of additional sharing and editing options.
  • What are the advantages of the 1-inch sensor camera on DJI Air 2S?
    DJI Air 2S features a 1-inch CMOS sensor, offering exceptional exposure sensitivity and dynamic range. A bigger sensor means the camera can collect more visual information, resulting in images and footage with stunningly rich detail. DJI Air 2S can also capture up to 12.6 stops in RAW, providing more details on highlights and shadows. This also allows more room for editing in post. A big sensor usually means a larger, heavier drone, but not with DJI Air 2S. DJI Air 2S still weighs less than 600g, making it the ideal choice for aerial photography on the go.
  • What are the advantages of MasterShots?
    The next level of content creation, MasterShots provide automatic aerial imaging and editing. According to the type and distance of the target, DJI Air 2S automatically selects from Proximity, Landscape, and Portrait templates and executes a cinematic sequence of shots. After shooting is complete, footage is edited automatically, with diverse templates available for impressive videos with a single tap.
  • How has the O3 transmission system been improved compared to DJI Mavic Air 2's OcuSync 2.0?
    Equipped with a brand new transmission solution, O3 has four antennas and supports two frequency bands. It features stronger interference resistance, delivers full-HD video transmission feeds from up to 12 km away (when unobstructed, free of interference, and FCC-compliant), and enables more reliable transmission in complex environments.
  • I am a beginner/new pilot. Where can I find tips about using DJI Air 2S?
    The DJI Fly app comes with beginner-friendly tutorials to help users start flying quickly and safely. With the combination of intelligent functions and safety technology, DJI Air 2S lets you spend more time enjoying flights and less time worrying about them.
  • Which microSD card should I use?
    UHS-I Speed Grade 3 micro SD cards are recommended:
    SanDisk Extreme PRO 64GB V30 A2 microSDXC
    SanDisk High Endurance 64GB V30 microSDXC
    SanDisk Extreme 64GB V30 A2 microSDXC
    SanDisk Extreme 128GB V30 A2 microSDXC
    SanDisk Extreme 256GB V30 A2 microSDXC
    Lexar Lexar 667x 64GB V30 A2 microSDXC
    Lexar High-Endurance 64GB V30 microSDXC
    Samsung EVO 64GB microSDXC
    Samsung EVO Plus 64GB microSDXC
    Samsung EVO Plus 256GB microSDXC
    Kingston 128GB V30 microSDXC
    Netac 256GB A1 microSDXC
  • What app do I need for DJI Air 2S?
    DJI Air 2S can only be used with the DJI Fly app. In addition to offering a streamlined user experience, the DJI Fly app contains flight tutorials so you can learn how to fly safely. To download the DJI Fly app, visit the official download page of DJI Air 2S.
** Vision positioning requires non-reflective, discernable surfaces, and adequate lighting. Available at altitudes from 0.5-30 m. The vertical and horizontal positioning accuracy is within ±0.1 m.
*** Omnidirectional Obstacle Sensing includes left/right, up/down, and forward/backward obstacle sensing. Sensing for left/right directions is only available in ActiveTrack , POI, QuickShot, and Tripod modes. Omnidirectional Obstacle Sensing does not fully cover the circumference of a 360-degree arc. And left and right obstacle sensing system only works in specific modes and environments. DJI warranty does not cover any loss caused by crashing when flying left or right, even when ActiveTrack or Tripod mode is activated. Please be aware of your surroundings and App notifications when operating the Mavic 2 to ensure safety.
